BASIC4MCU | AVR | 타이머 | ds12c887 RTC
작성자 키트 작성일2017-08-29 09:30 조회4,913회 댓글0건본문
//===================================================================// 코드비젼//===================================================================#pragma opt- //코드 최적화 금지//===================================================================#include <mega128.h>#include <stdio.h>#include <delay.h>//===================================================================#define U_C unsigned char#define U_I unsigned int//===================================================================//Port - C Bit Assign//===================================================================// rtc data bus#define PC_DDR 0x00 // Port-C Direction#define PC_INI 0xFF // Port-C Init#define RTC_IN PINC#define RTC_OUT PORTC//#define PD_DDR 0x0F // Port-D Direction#define PD_INI 0x0D // Port-D Init#define RTC_CS PORTD.0 // Lo Active#define RTC_AS PORTD.1 // Hi Active#define RTC_WR PORTD.2 // Lo Active#define RTC_RD PORTD.3 // Lo Active//===================================================================#define Rtc_Sec 0x00 // DS12C887 RTC#define Rtc_SEC_ALM 0x01#define Rtc_Min 0x02#define Rtc_MIN_ALM 0x03#define Rtc_Hour 0x04#define Rtc_Hour_ALM 0x05#define Rtc_WEEKDay 0x06#define Rtc_Date 0x07#define Rtc_Mon 0x08#define Rtc_Year 0x09#define Rtc_A //uip,dv2,dv1,dv0,rs3,rs2,rs1,rs0#define Rtc_B //set,pie,aie,uie,sqwe,DM=0,24=1,dse#define Rtc_C //irqf,pf,af,uf,0,0,0,0#define Rtc_D //VRT,0,0,0,0,0,0,0//#define Rtc_FLAG 0x0F//User ram 'G' 체크용//#define Rtc_CHKYY 0x0E//User ram 년도 체크용//#define Rtc_10Year 0x32//세기년도//===================================================================//===================================================================U_C Year, Mon, Date, Hour, Min, Sec;U_C Time[7], lcd_buf[20];//===================================================================void RTC_Write(U_C Add, U_C Data);U_C RTC_Read(U_C Add);void Init_Time(void);void Get_Time(void);void Save_Time(void);//===================================================================void RTC_Write(U_C Add, U_C Data){DDRC=0xFF; RTC_CS=0; RTC_OUT=Add; RTC_AS=1; RTC_AS=0;RTC_OUT=Data; RTC_WR=0; RTC_WR=1; RTC_CS=1; DDRC=0;}//===================================================================U_C RTC_Read(U_C Add){ U_C Data;DDRC=0xFF; RTC_CS=0; RTC_OUT=Add; RTC_AS=1; RTC_AS=0;DDRC=0; RTC_RD=0; Data=RTC_IN; RTC_RD=1; RTC_CS=1;return Data;}//===================================================================void Init_Time(void){Year=9; Mon=5; Date=0x20; Hour=0x12; Min=0;Save_Time();}//===================================================================void Get_Time(void){Year=RTC_Read(Rtc_Year); Mon =RTC_Read(Rtc_Mon);Date=RTC_Read(Rtc_Date); Hour=RTC_Read(Rtc_Hour);Min =RTC_Read(Rtc_Min); Sec =RTC_Read(Rtc_Sec);if(Year>0x99){ Init_Time(); }else if(((Mon & 0xf0)>0x10)||((Mon & 0xf)>0x9)){ Init_Time(); }else if(((Date& 0xf0)>0x30)||((Date& 0xf)>0x9)){ Init_Time(); }else if(((Hour& 0xf0)>0x20)||((Hour& 0xf)>0x9)){ Init_Time(); }else if(((Min & 0xf0)>0x50)||((Min & 0xf)>0x9)){ Init_Time(); };Time[0]=Year; Time[1]=Mon; Time[2]=Date;Time[3]=Hour; Time[4]=Min; Time[5]=Sec;}//===================================================================void Save_Time(void){RTC_Write(Rtc_Year,Year); RTC_Write(Rtc_Mon,Mon);RTC_Write(Rtc_Date,Date); RTC_Write(Rtc_Hour,Hour);RTC_Write(Rtc_Min, Min); RTC_Write(Rtc_Sec, Sec);}//===================================================================//===================================================================void main(void){PORTC=PC_INI; PORTD=PD_INI; DDRC=PC_DDR; DDRD=PD_DDR;RTC_Write(Rtc_B,0x82); RTC_Write(Rtc_A,0x20); RTC_Write(Rtc_B,0x02); //RTC Initwhile(1){Get_Time();sprintf(lcd_buf," %02x/%02x %02x:%02x:%02x ",Mon,Date,Hour,Min,Sec);};}//==============================================================================================
조회수 4,913등록된 댓글이 없습니다.
