BASIC4MCU | ★=STM32_IDE=★ | HAL - LL | STM32Cube MCU Packages
작성자 master 작성일2018-01-30 15:01 조회1,953회 댓글0건본문
STM32 Embedded Software
Low level drivers, hardware abstraction layers, and middleware like RTOS, USB stacks, graphic stacks, are indispensable bricks for a fast and efficient application development.
For the STM32, ST proposes a large range of embedded software components including
- Audio (MP3, WMA, Voice, ...)
- Connectivity (USB, TCP/IP, Bluetooth, Zigbee RF4CE, ...)
- Graphical Interfaces
- Cryptography (Free STM32 Library with public key, symetric and hash algorithms),
- Motor Control and Safety (IEC 61508 SIL for industrial, 60335/60730 Class B for Home Appliance)
These components are either developed by ST or supplied, ST's partner network or stem from open source initiatives.
With the STM32Cube ST follows a new route for embedded software by integrating low level and middleware software in one library and by supplying a configuration tool, capable of generating initialization code for the application.
PRODUCT TREE
With STM32Cube, STMicroelectronics provides a comprehensive software tool, significantly reducing development efforts, time and cost.
STM32Cube consists of (usable together or independently):
- The STM32CubeMX, featuring:
- Configuration C code generation for pin multiplexing, clock tree, peripherals and middleware setup with graphical wizards
- Generation of IDE ready projects for a integrated development environment tool chains
- Power consumption calculation for a user-defined application sequence
- Direct import of STM32 Cube embedded software libraries from st.com
- Integrated updater to keep STM32CubeMX up-to-date
- STM32Cube MCU Package including:
- The HAL hardware abstraction layer, enabling portability between different STM32 devices via standardized API calls
- The Low-Layer (LL) APIs, a light-weight, optimized, expert oriented set of APIs designed for both performance and runtime efficiency
- A collection of Middleware components, like RTOS, USB library, file system, TCP/IP stack, Touch sensing library or Graphic Library (depending on the MCU series)
RESOURCES
조회수 1,953등록된 댓글이 없습니다.
