♧ STM32F2 > NUCLEO-F207ZG
TODAY232 TOTAL2,698,037
BASIC4MCU | ♧ STM32F2 | F207_ZG_Nucleo | NUCLEO-F207ZG
작성자 master 작성일2018-02-19 17:39 조회1,510회 댓글0건
STM32 MCU Eval Tools
?src=%22http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Ffragment%2Fproduct_related%2Fseries_information%2Fseries_level_diagram%2F34%2F6f%2F9f%2F27%2F7d%2Ffc%2F43%2Ffd%2Fss1532_stm32_eval_tools.png%2Ffiles%2Fss1532_stm32_eval_tools.png%2F_jcr_content%2Ftranslations%2Fen.ss1532_stm32_eval_tools.png%22&type=cafe_wa740
STM32 MCU Nucleo
All STM32 Nucleo users have free access to the mbed online resources (compiler, C/C++ SDK, and developer community) at www.mbed.org allowing to build a complete application in only a few minutes.
?src=%22http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Ffragment%2Fproduct_related%2Fline_information%2Fline_level_diagram%2Ff0%2Fb8%2F25%2F69%2F66%2F01%2F45%2Fdd%2Fln1847_stm32_nucleo.jpg%2Ffiles%2Fln1847_stm32_nucleo.jpg%2F_jcr_content%2Ftranslations%2Fen.ln1847_stm32_nucleo.jpg%22&type=cafe_wa740
NUCLEO-F207ZG
STM32 Nucleo-144 development board with STM32F207ZG MCU, supports Arduino, ST Zio and morpho connectivity
The STM32 Nucleo-144 boards provide an affordable and flexible way for users to try out new concepts and build prototypes by choosing from the various combinations of performance and power consumption features, provided by the STM32 microcontroller. For the compatible boards, the SMPS significantly reduces power consumption in Run mode.
The ST Zio connector, which extends the Arduino™ Uno V3 connectivity, and the ST morpho headers provide an easy means of expanding the functionality of the Nucleo open development platform with a wide choice of specialized shields.
The STM32 Nucleo-144 board does not require any separate probe as it integrates the ST-LINK/V2-1 debugger/programmer.
The STM32 Nucleo-144 board comes with the STM32 comprehensive free software libraries and examples available with the STM32Cube MCU Package.
Key Features
  • STM32 microcontroller in LQFP144 package
  • External SMPS to generate Vcore logic supply (only available on '-P' suffixed boards)
  • Ethernet compliant with IEEE-802.3-2002 (depending on STM32 support)
  • USB OTG or full-speed device (depending on STM32 support)
  • 3 user LEDs
  • 2 user and reset push-buttons
  • 32.768 kHz crystal oscillator
  • Board connectors:
    • USB with Micro-AB
    • SWD
    • Ethernet RJ45 (depending on STM32 support)
    • ST Zio connector including Arduino™ Uno V3
    • ST morpho
  • Flexible power-supply options: ST-LINK USB VBUS or external sources
  • On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability: mass storage, virtual COM port and debug port
  • Comprehensive free software libraries and examples available with the STM32Cube package
  • Support of a wide choice of Integrated Development Environments (IDEs) including IAR™ , Keil® , GCC-based IDEs, Arm®Mbed™
  • Arm® Mbed Enabled™ compliant (only for some Nucleo part numbers)
?src=%22http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Ffragment%2Fproduct_related%2Frpn_information%2Fboard_photo%2Fgroup0%2F22%2F8e%2F71%2F7e%2Fa8%2F9a%2F43%2F61%2Fhigh-perf_nucleo-144_mbed%2Ffiles%2Fhigh-perf_nucleo-144_mbed.jpg%2F_jcr_content%2Ftranslations%2Fen.high-perf_nucleo-144_mbed.jpg%22&type=cafe_wa740
Technical Documentation
Product Specifications
DescriptionVersionSize
DB3171DB3171: STM32 Nucleo-144 boards6.0386 KB
Technical Notes & Articles
TN1235TN1235: Overview of the ST-LINK embedded in STM32 MCU Nucleo, Discovery Kits and Eval Boards1.0155 KB
User Manuals
UM1727UM1727: Getting started with STM32 Nucleo board software development tools5.02 MB
UM1974UM1974: STM32 Nucleo-144 boards7.02 MB
Hardware Resources
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32 Nucleo (144 pins) gerber files1.0571 KB
Bill of Materials
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32 Nucleo (144 pins) BOM5.0319 KB
Schematic Pack
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32 Nucleo (144 pins) schematics1.15 MB
Publications and Collaterals
Flyers
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 Nucleo boards - Unified scalable offering17.111 MB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 for makers - Releasing your creativity17.062 MB
Brochures
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 32-bit MCU family - Leading supplier of ARM® Cortex®-M microcontrollers17.102 MB
Legal
License Agreement
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Evaluation products license agreement1.4128 KB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Open Reference Material License Agreement v542 KB
TOOLS AND SOFTWARE
Development Tools
SOFTWARE DEVELOPMENT TOOLS
Embedded Software
MCUS EMBEDDED SOFTWARE
Evaluation Tools
PRODUCT EVALUATION TOOLS
SAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office  or our Distributors
QUALITY & RELIABILITY
Part NumberMarketing StatusRoHS Compliance GradeMaterial Declaration**
NUCLEO-F207ZGActiveEcopack1
(**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
조회수 1,510
♧ STM32F2HOME > ♧ STM32F2 > 전체 목록
♧ STM32F2 목록
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 19826
공지 사이트 이용 안내댓글[28] master 17-10-29 34162
5 F217_IG_EVAL STM3221G-EVAL master 18-02-19 1591
현재글 F207_ZG_Nucleo NUCLEO-F207ZG master 18-02-19 1511
3 F207_IG_EVAL STM3220G-EVAL master 18-02-19 1253
2 ◆F2x5 F2x7 master 18-02-19 1407
1 ◆F2x5 F2x5 master 18-02-19 1392
