BASIC4MCU | ♧ STM32F3 | F373_VC_EVAL | STM32373C-EVAL
작성자 master 작성일2018-02-19 17:45 조회1,345회 댓글0건본문
STM32 MCU Eval Tools
STM32 MCU Eval Boards
The STM32 eval boards have been designed as a complete demonstration and development platform for the ARM Cortex STM32 MCUs.
They carry external circuitry, such as transceivers, sensors, memory interfaces, displays and many more. The evaluation boards can be considered as a reference design for application development.
STM32373C-EVAL
Evaluation board with STM32F373VC MCUThe STM32373C-EVAL evaluation board is designed as a complete demonstration and development platform for STMicroelectronics ARM Cortex-M4 core-based STM32F373VCT6 microcontroller. It features two I2Cs, three SPIs, three USARTs, one CAN, one CEC controller, one 12-bit ADC, three 16-bit sigma delta ADCs, three 12-bit DACs, internal 32-KByte SRAM and 256-KByte Flash, touch sensing slider, USB FS, and JTAG debugging support. This evaluation board can be used as a reference design for user application development but it is not considered as the final application.
The full range of hardware features on the board can help the user evaluate all peripherals (USB FS, USART, audio DAC, microphone ADC, dot-matrix LCD, IrDA, LDR, MicroSD card, HDMI CEC, ECG, pressure sensor, CAN, IR transmitter and receiver, EEPROM, touch slider, temperature sensor, etc.) and develop their own applications. Extension headers make it possible to easily connect a daughter board or wrapping board for a specific application.
An ST-LINK/V2 is integrated on the board as an embedded in-circuit debugger and programmer for the STM32 MCU.
The STM32373C-EVAL evaluation board does not support STM32F3x8 MCUs (1.65 V to 1.95 V power supply).
Key Features
- STM32F373VCT6 microcontroller
- Four 5 V power supply options:
- Power jack
- ST-LINK/V2 USB connector
- User USB connector
- Daughter board
- Audio jack connected to I2 S DAC
- Microphone connected to ADC through an amplifier
- 2-GByte (or more) MicroSD card on SPI
- Three components on I2 C bus: temperature sensor, EEPROM and dual interface RF EEPROM
- RS-232 communication configurable for communication of Flash loader
- IrDA transceiver
- 240x320 TFT color LCD connected to SPI interface
- Joystick with 4-direction control and selector
- Reset, Wakeup or Tamper, and Key buttons
- 4 color user LEDs
- 2 LEDs for MCU power range indicator
- ECG, pressure sensor and PT100 temperature sensor connected to the 16-bit Sigma Delta ADC of STM32F373VCT6
- Extension connectors for daughter board or wrapping board
- MCU voltage: 3.3 V or adjustable 2.0 V - 3.6 V
- USB FS connector
- Touch slider
- RTC with backup battery
- CAN 2.0 A/B compliant connection
- Light dependent resistor (LDR)
- Two HDMI connectors with DDC and CEC
- IR transmitter and receiver
- Two ADC & DAC input and output signal connectors and one Sigma Delta ADC input signal connector
- Potentiometer
- JTAG/SWD and ETM trace debug support
- Embedded ST-LINK/V2
Technical Documentation
Product Specifications
Description Version Size DB1741: Evaluation board for STM32F373xx microcontrollers 3.0 267 KB Technical Notes & Articles
Description Version Size TN1235: Overview of the ST-LINK embedded in STM32 MCU Nucleo, Discovery Kits and Eval Boards 1.0 155 KB User Manuals
Description Version Size UM1564: STM32373C-EVAL evaluation board 1.1 1 MB Hardware Resources
Description Version Size STM32373C-EVAL gerber files 1.1 2 MB Bill of Materials
Description Version Size STM32373C-EVAL BOM 2.0 6 KB Schematic Pack
Description Version Size STM32373C-EVAL schematics 1.0 2 MB Publications and Collaterals
Flyers
Description Version Size STM32 for makers - Releasing your creativity 17.06 2 MB Brochures
Description Version Size STM32 32-bit MCU family - Leading supplier of ARM® Cortex®-M microcontrollers 17.10 2 MB STM32F3 series - Mainstream 32-bit MCUs 17.09 2 MB Legal
License Agreement
Description Version Size Evaluation products license agreement 1.4 128 KB Open Reference Material License Agreement v5 42 KB TOOLS AND SOFTWARE
Development ToolsSOFTWARE DEVELOPMENT TOOLSEmbedded SoftwareMCUS EMBEDDED SOFTWARESAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office or our Distributors
QUALITY & RELIABILITY
Part Number RoHS Compliance Grade Material Declaration** STM32373C-EVAL Ecopack1 (**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
조회수 1,345등록된 댓글이 없습니다.
