♧ STM32F3 > NUCLEO-F302R8
TODAY379 TOTAL2,160,390
BASIC4MCU | ♧ STM32F3 | F302_R8_Nucleo | NUCLEO-F302R8
작성자 master 작성일2018-02-19 17:40 조회1,283회 댓글0건
STM32 MCU Eval Tools
?src=%22http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Ffragment%2Fproduct_related%2Fseries_information%2Fseries_level_diagram%2F34%2F6f%2F9f%2F27%2F7d%2Ffc%2F43%2Ffd%2Fss1532_stm32_eval_tools.png%2Ffiles%2Fss1532_stm32_eval_tools.png%2F_jcr_content%2Ftranslations%2Fen.ss1532_stm32_eval_tools.png%22&type=cafe_wa740
STM32 MCU Nucleo
All STM32 Nucleo users have free access to the mbed online resources (compiler, C/C++ SDK, and developer community) at www.mbed.org allowing to build a complete application in only a few minutes.
?src=%22http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Ffragment%2Fproduct_related%2Fline_information%2Fline_level_diagram%2Ff0%2Fb8%2F25%2F69%2F66%2F01%2F45%2Fdd%2Fln1847_stm32_nucleo.jpg%2Ffiles%2Fln1847_stm32_nucleo.jpg%2F_jcr_content%2Ftranslations%2Fen.ln1847_stm32_nucleo.jpg%22&type=cafe_wa740
NUCLEO-F302R8
STM32 Nucleo-64 development board with STM32F302R8 MCU, supports Arduino and ST morpho connectivity
The STM32 Nucleo board provides an affordable and flexible way for users to try out new concepts and build prototypes with the STM32 microcontroller, choosing from the various combinations of performance, power consumption and features. For the compatible boards, the SMPS significantly reduces power consumption in Run mode.
The Arduino™ Uno V3 connectivity support and the ST morpho headers allow the easy expansion of the functionality of the STM32 Nucleo open development platform with a wide choice of specialized shields.
The STM32 Nucleo board does not require any separate probe as it integrates the ST-LINK/V2-1 debugger and programmer.
The STM32 Nucleo board comes with the STM32 comprehensive software HAL library together with various packaged software examples, as well as direct access to the Arm® Mbed™ online resources at http://mbed.org.
Key Features
  • STM32 microcontroller in LQFP64 package
  • External SMPS to generate Vcore logic supply (only available on '-P' suffixed boards)
  • 1 user LED shared with Arduino™
  • 1 user and 1 reset push-buttons
  • 32.768 kHz LSE crystal oscillator
  • Board expansion connectors:
    • Arduino™ Uno V3
    • ST morpho extension pin headers for full access to all STM32 I/Os
    • External SMPS experimentation dedicated connector (only available on '-P' suffixed boards)
  • Flexible power-supply options: ST-LINK USB VBUS or external sources
  • On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability. Three different interfaces supported on USB: mass storage, virtual COM port and debug port
  • Comprehensive free software libraries and examples available with the STM32Cube MCU Package
  • Support of a wide choice of Integrated Development Environments (IDEs) including IAR™ , Keil® , GCC-based IDEs, Arm®Mbed™
  • Arm® Mbed Enabled™ compliant (only for some Nucleo part numbers)
?src=%22http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Ffragment%2Fproduct_related%2Frpn_information%2Fboard_photo%2F2e%2F4a%2F01%2F43%2F4f%2Ffa%2F4a%2F3d%2Fnucleo-F1.jpg%2Ffiles%2Fnucleo-F1.jpg%2F_jcr_content%2Ftranslations%2Fen.nucleo-F1.jpg%22&type=cafe_wa740
Technical Documentation
Product Specifications
DescriptionVersionSize
DB2196DB2196: STM32 Nucleo-64 boards10.0387 KB
Technical Notes & Articles
TN1235TN1235: Overview of the ST-LINK embedded in STM32 MCU Nucleo, Discovery Kits and Eval Boards1.0155 KB
User Manuals
UM1727UM1727: Getting started with STM32 Nucleo board software development tools5.02 MB
UM1724UM1724: STM32 Nucleo-64 boards12.03 MB
Presentations & Training Material
Presentations
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 PMSM FOC SDK Getting Started1.65 MB
Hardware Resources
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32 Nucleo (64 pins) gerber files1.0900 KB
Bill of Materials
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32 Nucleo (64 pins) BOM2.0192 KB
Schematic Pack
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32 Nucleo (64 pins) schematics1.0958 KB
Publications and Collaterals
Flyers
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 Nucleo boards - Unified scalable offering17.111 MB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 for makers - Releasing your creativity17.062 MB
Brochures
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 32-bit MCU family - Leading supplier of ARM® Cortex®-M microcontrollers17.102 MB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32F3 series - Mainstream 32-bit MCUs17.092 MB
Legal
License Agreement
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Evaluation products license agreement1.4128 KB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Open Reference Material License Agreement v542 KB
TOOLS AND SOFTWARE
Development Tools
SOFTWARE DEVELOPMENT TOOLS
Ecosystems
STM32 OPEN DEVELOPMENT ENVIRONMENT
Embedded Software
MCUS EMBEDDED SOFTWARE
Evaluation Tools
PRODUCT EVALUATION TOOLS
SAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office  or our Distributors
QUALITY & RELIABILITY
Part NumberMarketing StatusRoHS Compliance GradeMaterial Declaration**
NUCLEO-F302R8ActiveEcopack1
(**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
http://www.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-tools/mcu-eval-tools/stm32-mcu-eval-tools/stm32-mcu-nucleo/nucleo-f302r8.html
조회수 1,283
♧ STM32F3HOME > ♧ STM32F3 > 전체 목록
