BASIC4MCU | ♧ STM32F3 | ◆F303 Performance | F303 Performance
작성자 master 작성일2018-02-19 17:41 조회1,558회 댓글0건본문
STM32F3 Series
STM32 F3 series of mixed-signal MCUs with DSP and FPU instructions
The STM32 F3 series combines a 32-bit ARM® Cortex®-M4 core (with FPU and DSP instructions) running at 72 MHz with a high number of integrated analog peripherals leading to cost reduction at application level and simplifying application design, including:
- Ultra-fast comparators (25 ns)
- Op-amp with programmable gain
- 12-bit DACs
- Ultra-fast 12-bit ADCs with 5 MSPS (Million Samples Per Second) per channel (up to 18 MSPS in Interleaved mode)
- Precise 16-bit sigma-delta ADCs (21 channels)
- Core Coupled Memory SRAM (Routine Booster), a specific memory architecture boosting time-critical routines, accelerating the performance by 43%
- 144 MHz Advanced 16-bit pulse-width modulation timer (resolution < 7 ns) for control applications
- High resolution timer (217 picoseconds), self-compensated vs power supply and temperature drift
A flexible interconnect matrix allows autonomous communication between peripherals and saves CPU resources and power consumption.
A high degree of compatibility with STM32 F0 series guarantees outstanding efficiency when designing derivatives of applications at different performance levels.
The STM32 F3 series consists of:
- The STM32F301, STM32F302, STM32F303 general-purpose product lines ranging from a basic, cost-efficient peripheral set, up to more performance and analog functions able to manage up to triple FOC motor control,
- The STM32F334 with high-resolution timer (217 picoseconds) and complex waveform builder plus event handler (HRTIM) for digital power conversion, such as digital switched-mode power supplies, lighting, welding, solar and wireless charging,
- The STM32F373, with 16-bit sigma-delta ADC and
7 built-in gains for high-precision measurements in applications such as biometric sensors or smart metering,- The STM32F3x8 line, supporting 1.8 volt operation
Package options are LQPF48/64/100, UFBGA100, WLCSP100/66/49, UQFN32 for the devices ranging now from
16 up to 512 Kbytes of Flash memory.
Temperature range from -40 to 85 ° C or from -40 to 105 ° C (with a junction temperature of 125 ° C).
STM32F303 Performance
The STM32F303 are mixed-signal MCUs with an ARM® Cortex®-M4 core (with FPU and DSP instructions) running at 72 MHz.
These are the superset devices in the STM32F30x seriesThe devices are equipped with:
- Up to 7x fast- and ultra-fast comparators (25 ns)
- Up to 4x Op-Amp with programmable gain
- Up to 2x 12-bit DACs
- Up to 4x ultra-fast 12-bit ADCs with 5 MSPS
- Up to 3x fast 144 megahertz motor control timers (resolution < 7 ns)
- Full-speed USB and CAN 2.0B communication interfaces
- Core Coupled Memory SRAM (Routine Booster), a specific memory architecture boosting time-critical routines, accelerating the performance by 43% compared to Flash execution
The STM32F303 microcontrollers operate from 2 to 3.6 Volts.
Memory ranges from 32 to 512 Kbytes and packages from 32 to 144 pins.
조회수 1,558등록된 댓글이 없습니다.
