♧ STM32F7 > STM32F769I-EVAL
TODAY891 TOTAL2,585,063
BASIC4MCU | ♧ STM32F7 | F769_NI_EVAL | STM32F769I-EVAL
작성자 master 작성일2018-04-19 10:10 조회2,015회 댓글0건
STM32 MCU Eval Tools
STM32 MCU Eval Boards
The STM32 eval boards have been designed as a complete demonstration and development platform for the ARM Cortex STM32 MCUs.
They carry external circuitry, such as transceivers, sensors, memory interfaces, displays and many more. The evaluation boards can be considered as a reference design for application development.
STM32F769I-EVAL
Evaluation board with STM32F769NI MCU
The STM32F769I-EVAL evaluation board is a complete demonstration and development platform for STMicroelectronics ARM®Cortex®-M7 core-based STM32F769NI microcontrollers. It features the following interfaces: four I2Cs, six SPIs with three multiplexed full-duplex I2S, SDIO, two SAIs, 8- to 14-bit digital camera module, Ethernet MAC, FMC and Quad-SPI. It also features four USART and four UART peripherals, two CAN bus, three 12-bit ADC converters, two 12-bit DAC channels, internal 256+4-Kbyte SRAM and 2-Mbyte Flash memory, USB HS OTG and USB FS OTG peripherals, JTAG debugging support. This evaluation board can be used as a reference design for user application development but it is not considered as a final application.
The full range of hardware features on the board helps the user to evaluate all the peripherals (USB OTG HS, USB OTG FS, Ethernet, motor control, CAN, microSD card, USART, audio DAC and ADC, digital microphone, CAN, SRAM, NOR Flash, SDRAM, Quad-SPI Flash, 4" DSI LCD with capacitive touch panel etc.) and to develop applications. Extension headers make it possible to easily connect a daughterboard for a specific application.
The integrated ST-LINK/V2-1 provides an embedded in-circuit debugger and programmer for the STM32.
Key Features
  • STM32F769NI microcontroller with 2-Mbyte Flash memory and 512+16+4-Kbyte RAM in BGA216 package
  • Six 5 V power supply options:
    • Power jack
    • ST-LINK/V2-1 Micro-B USB connector
    • User USB HS connector
    • User USB FS1 connector
    • User USB FS2 connector
    • Daughterboard
  • SAI audio DAC, stereo audio jack that supports headset with microphone
  • Stereo digital microphone, audio jack connector used to connect external speakers
  • 2-Gbyte (or more) SDIO interface microSD card
  • Four I2 C interfaces
  • RS-232 communication
  • JTAG/SWD and ETM trace debug support, ST-LINK/V2-1 embedded
  • IEEE-802.3-2002 compliant Ethernet connector
  • Camera module
  • 8Mx32bit SDRAM, 1Mx16bit SRAM and 8Mx16bit NOR Flash
  • 512-Mbit Quad-SPI NOR Flash
  • 2Gx16bit NAND Flash interface to connect NAND Flash module
  • 4" capacitive touch LCD display with MIPI® DSI connector
  • Joystick with 4-direction control and selector
  • Reset, Wake Up/Tamper or key button
  • 4-color user LEDs
  • Extension and memory connectors for daughterboard or wrapping board
  • USB OTG HS and FS with Micro-AB connectors
  • RTC with backup battery
  • CAN2.0A/B compliant connection
  • Potentiometer
  • Motor control connector
Technical Documentation
Product Specifications
DescriptionVersionSize
DB2877DB2877: Evaluation board with STM32F769NI MCU1.0304 KB
Technical Notes & Articles
TN1235TN1235: Overview of the ST-LINK embedded in STM32 MCU Nucleo, Discovery Kits and Eval Boards1.0155 KB
User Manuals
UM2035UM2035: Evaluation board with STM32F769NI MCU3.02 MB
Hardware Resources
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32F769I-EVAL and STM32F779I-EVAL gerber files1.0.02 MB
Bill of Materials
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32F769I-EVAL and STM32F779I-EVAL BOM1.0.09 KB
Schematic Pack
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740STM32F769I-EVAL and STM32F779I-EVAL schematics1.0.06 MB
Publications and Collaterals
Flyers
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 for makers - Releasing your creativity17.062 MB
Brochures
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 32-bit MCU family - Leading supplier of ARM® Cortex®-M microcontrollers17.102 MB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32F7 series - ARM® Cortex®-M7 powered17.021 MB
Legal
License Agreement
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Evaluation products license agreement1.4128 KB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Open Reference Material License Agreement v542 KB
TOOLS AND SOFTWARE
Development Tools
HARDWARE DEVELOPMENT TOOLS
SOFTWARE DEVELOPMENT TOOLS
Embedded Software
MCUS EMBEDDED SOFTWARE
SAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office  or our Distributors
QUALITY & RELIABILITY
Part NumberMarketing StatusRoHS Compliance GradeMaterial Declaration**
STM32F769I-EVALActiveEcopack1
(**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
http://www.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-tools/mcu-eval-tools/stm32-mcu-eval-tools/stm32-mcu-eval-boards/stm32f769i-eval.html
조회수 2,015
♧ STM32F7HOME > ♧ STM32F7 > 전체 목록
