♧ STM32L0 > B-L072Z-LRWAN1
TODAY1,001 TOTAL2,440,804
BASIC4MCU | ♧ STM32L0 | L072 LRWAN1_Discovery | B-L072Z-LRWAN1
작성자 master 작성일2018-03-14 09:15 조회1,507회 댓글0건
STM32 MCU Eval Tools
STM32 MCU Discovery Kits
STM32 Discovery kits are a cheap and complete solution for the evaluation of the outstanding capabilities of STM32 MCUs. They carry the necessary infrastructure for demonstration of specific device characteristics, a HAL library and comprehensive software examples allow to fully benefit from the devices features and added values.
Extension connectors give access to most of the device’s I/Os and make the connection of add-on hardware possible.
With the integrated debugger/programmer the discovery kits are ideal for prototyping.
B-L072Z-LRWAN1
STM32L0 Discovery kit LoRa, low-power wireless
The B-L072Z-LRWAN1 LoRa®Discovery kit is a development tool to learn and develop solutions based on LoRa®and FSK/OOK technologies. This Discovery kit features an all-in-one open module CMWX1ZZABZ-091 (by Murata). The module is powered by an STM32L072CZ and an SX1276 transceiver. The transceiver features the LoRa®long-range modem, providing ultra-long-range spread spectrum communication and high interference immunity, minimizing current consumption. Since CMWX1ZZABZ-091 is an open module, user has access to all STM32L072 peripherals such as ADC, 16-bit timer, LP-UART, I2C, SPI and USB 2.0 FS (supporting BCD and LPM).
The B-L072Z-LRWAN1 Discovery kit includes an ST-LINK/V2-1 embedded debug tool interface, LEDs, push-buttons, antenna, Arduino™Uno V3 connectors and USB OTG connector in Micro-B format.
The LoRaWAN™stack is certified class A and C compliant. It is available inI-CUBE-LRWAN firmware package. Several examples, as an AT-command stack, are available to help users setting up a complete LoRaWAN™node.
Key Features
  • CMWX1ZZABZ-091 LoRa® module (Murata)
    • Embedded ultra-low-power STM32L072CZ Series MCUs, based on ARM® Cortex® -M0+ core, with 192 Kbytes of Flash memory, 20 Kbytes of RAM, 20 Kbytes of EEPROM
    • USB 2.0 FS
    • 4-channel,12-bit ADC, 2xDAC
    • 6-bit timers, LP-UART, I2 C and SPI
    • Embedded SX1276 transceiver
    • LoRa® , FSK, GFSK, MSK, GMSK and OOK modulations
    • +14 dBm or +20 dBm selectable output power
    • 157 dB maximum link budget
    • Programmable bit rate up to 300 Kbit/s
    • High sensitivity: down to -137 dBm
    • Bullet-proof front end: IIP3 = -12.5 dBm
    • 89 dB blocking immunity
    • Low RX current of 10 mA, 200 nA register retention
    • Fully integrated synthesizer with a resolution of 61 Hz
    • Built-in bit synchronizer for clock recovery
    • Sync word recognition
    • Preamble detection
    • 127 dB+ dynamic range RSSI
  • SMA and U.FL RF interface connectors
  • Including 50 Ohm SMA RF antenna
  • On-board ST-LINK/V2-1 supporting USB re-enumeration capability
  • USB ST-LINK functions:
  • Board power supply:
    • Through USB bus or external VIN /3.3 V supply voltage or batteries
  • 3xAAA-type-battery holder for standalone operation
  • 7 LEDs:
    • 4 general-purpose LEDs
    • A 5 V-power LED
    • An ST-LINK-communication LED
    • A fault-power LED
  • 2 push-buttons (user and reset)
  • Arduino™ Uno V3 connectors
  • ARM® mbed™ (see http://mbed.org)
Technical Documentation
Product Specifications
DescriptionVersionSize
DB3090DB3090: Discovery kit for LoRaWAN™ and LPWAN protocols with STM32L01.0297 KB
Technical Notes & Articles
TN1235TN1235: Overview of the ST-LINK embedded in STM32 MCU Nucleo, Discovery Kits and Eval Boards1.0155 KB
User Manuals
UM2115UM2115: Discovery kit for LoRaWAN™ and LPWAN protocols with STM32L03.02 MB
UM2052UM2052: Getting started with STM32 MCU Discovery Kits software development tools1.01 MB
UM2159UM2159: Getting started with Ultra-low-power STM32L0 and LoRa® Discovery kit1.0303 KB
Presentations & Training Material
Presentations
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740IoT connectivity made easier with STM32 MCUs and LoRa1.2.02 MB
Hardware Resources
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740B-L072Z-LRWAN1 Gerber files2.02 MB
Bill of Materials
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740B-L072Z-LRWAN1 BOM2.059 KB
Schematic Pack
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_zip.png%22&type=cafe_wa740B-L072Z-LRWAN1 Schematics2.08 MB
Publications and Collaterals
Flyers
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Get ready for the largest IoT development ecosystem17.02741 KB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 for makers - Releasing your creativity17.062 MB
Brochures
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32 32-bit MCU family - Leading supplier of ARM® Cortex®-M microcontrollers17.102 MB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740STM32L series - Ultra-low-power 32-bit MCUs16.43 MB
Quality & Reliability
Product Certifications
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Certificate of compliance LoRaWAN certified product delivered to Murata®276 KB
Legal
License Agreement
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Evaluation products license agreement1.4128 KB
?src=%22http%3A%2F%2Fwww.st.com%2Fetc%2Fclientlibs%2Fst-site%2Fmedia%2Fapp%2Fimages%2Ficon_pdf.png%22&type=cafe_wa740Open Reference Material License Agreement v542 KB
TOOLS AND SOFTWARE
Development Tools
SOFTWARE DEVELOPMENT TOOLS
Embedded Software
MCUS EMBEDDED SOFTWARE
SAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office  or our Distributors
QUALITY & RELIABILITY
Part NumberMarketing StatusRoHS Compliance GradeMaterial Declaration**
B-L072Z-LRWAN1ActiveEcopack1
(**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
http://www.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-tools/mcu-eval-tools/stm32-mcu-eval-tools/stm32-mcu-discovery-kits/b-l072z-lrwan1.html
조회수 1,507
♧ STM32L0HOME > ♧ STM32L0 > 전체 목록
