BASIC4MCU | ♧ STM32L0 | L073_RZ_Nucleo | NUCLEO-L073RZ
작성자 master 작성일2018-03-14 09:26 조회1,338회 댓글0건본문
STM32 MCU Eval Tools
STM32 MCU Nucleo
All STM32 Nucleo users have free access to the mbed online resources (compiler, C/C++ SDK, and developer community) at www.mbed.org allowing to build a complete application in only a few minutes.
NUCLEO-L073RZ
STM32 Nucleo-64 development board with STM32L073RZ MCU, supports Arduino and ST morpho connectivityThe STM32 Nucleo board provides an affordable and flexible way for users to try out new concepts and build prototypes with the STM32 microcontroller, choosing from the various combinations of performance, power consumption and features. For the compatible boards, the SMPS significantly reduces power consumption in Run mode.
The Arduino™ Uno V3 connectivity support and the ST morpho headers allow the easy expansion of the functionality of the STM32 Nucleo open development platform with a wide choice of specialized shields.
The STM32 Nucleo board does not require any separate probe as it integrates the ST-LINK/V2-1 debugger and programmer.
The STM32 Nucleo board comes with the STM32 comprehensive software HAL library together with various packaged software examples, as well as direct access to the Arm® Mbed™ online resources at http://mbed.org.
Key Features
- STM32 microcontroller in LQFP64 package
- External SMPS to generate Vcore logic supply (only available on '-P' suffixed boards)
- 1 user LED shared with Arduino™
- 1 user and 1 reset push-buttons
- 32.768 kHz LSE crystal oscillator
- Board expansion connectors:
- Arduino™ Uno V3
- ST morpho extension pin headers for full access to all STM32 I/Os
- External SMPS experimentation dedicated connector (only available on '-P' suffixed boards)
- Flexible power-supply options: ST-LINK USB VBUS or external sources
- On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability. Three different interfaces supported on USB: mass storage, virtual COM port and debug port
- Comprehensive free software libraries and examples available with the STM32Cube MCU Package
- Support of a wide choice of Integrated Development Environments (IDEs) including IAR™ , Keil® , GCC-based IDEs, Arm®Mbed™
- Arm® Mbed Enabled™ compliant (only for some Nucleo part numbers)
Technical Documentation
Product Specifications
Description Version Size DB2196: STM32 Nucleo-64 boards 10.0 387 KB Technical Notes & Articles
Description Version Size TN1235: Overview of the ST-LINK embedded in STM32 MCU Nucleo, Discovery Kits and Eval Boards 1.0 155 KB User Manuals
Description Version Size UM1727: Getting started with STM32 Nucleo board software development tools 5.0 2 MB UM1724: STM32 Nucleo-64 boards 12.0 3 MB Presentations & Training Material
Presentations
Description Version Size IoT connectivity made easier with STM32 MCUs and LoRa 1.2.0 2 MB Hardware Resources
Description Version Size STM32 Nucleo (64 pins) gerber files 1.0 900 KB Bill of Materials
Description Version Size STM32 Nucleo (64 pins) BOM 2.0 192 KB Schematic Pack
Description Version Size STM32 Nucleo (64 pins) schematics 1.0 958 KB Publications and Collaterals
Flyers
Description Version Size Get ready for the largest IoT development ecosystem 17.02 741 KB STM32 Nucleo boards - Unified scalable offering 17.11 1 MB STM32 for makers - Releasing your creativity 17.06 2 MB BrochuresLegal
License Agreement
Description Version Size Evaluation products license agreement 1.4 128 KB Open Reference Material License Agreement v5 42 KB TOOLS AND SOFTWARE
Development ToolsSOFTWARE DEVELOPMENT TOOLSEmbedded SoftwareMCUS EMBEDDED SOFTWAREEvaluation ToolsPRODUCT EVALUATION TOOLSSAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office or our Distributors
QUALITY & RELIABILITY
Part Number RoHS Compliance Grade Material Declaration** NUCLEO-L073RZ Ecopack1 (**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
조회수 1,338등록된 댓글이 없습니다.
