BASIC4MCU | ♧ STM32L1 | L152_ZD_EVAL | STM32L152D-EVAL
작성자 master 작성일2018-03-15 14:36 조회2,168회 댓글0건본문
STM32 MCU Eval Tools
ST's tools for evaluation of the STM32, range from highly affordable community enabled tools up to fully equipped boards, ready for evaluation of every single feature of the selected MCU. All ST evaluation boards include an ST-LINK/V2 in-circuit debugger/programmer.STM32 Nucleo boards follow a lean approach and are ideal for prototyping and community usage. An Arduino™connector and the ST Morpho connector make an extension with application related add-on hardware easy. All I/Os of the MCU are easily accessible, the boards come with a HAL library and work with IAR, Keil, CCC based IDEs as well as the mbed™ online IDE.
STM32 MCU Eval Boards
The STM32 eval boards have been designed as a complete demonstration and development platform for the ARM Cortex STM32 MCUs.
They carry external circuitry, such as transceivers, sensors, memory interfaces, displays and many more. The evaluation boards can be considered as a reference design for application development.
STM32L152D-EVAL
Evaluation board with STM32L152ZD MCUThe STM32L152D-EVAL evaluation board is a complete demonstration and development platform for the STM32 L1 series of ultra-low-power MCUs and includes an STM32L152ZDT6 ARM Cortex-M3 32-bit microcontroller with 384 KB of Flash memory. An ST-LINK/V2 is integrated on the board as an embedded in-circuit debugger / programmer for the STM32L152ZDT6. The full range of hardware features on the board helps you develop your own applications and evaluate all peripherals (USB FS, USART, audio DAC, microphone ADC, dot-matrix LCD, LCD glass, IrDA, LDR, SRAM, NOR Flash, MicroSD Card, temperature sensor and so on).
Extension headers facilitate easy connection of daughterboard or wrapping board for your application.
Key Features
- STM32L152ZDT6 microcontroller
- Four 5 V power supply options:
- Power jack
- ST-LINK/V2 USB connector
- User USB connector
- Daughterboard
- Audio jack connected to I2S DAC or STM32L152ZDT6 internal DAC
- Microphone connected to ADC using integrated op amp as amplifier
- 2 GByte (or more) MicroSD Card on SDIO
- Temperature sensor and RF EEPROM on I2C compatible serial interface
- RS-232 interface configurable for communication or Flash loader
- IrDA transceiver
- 4 Kbit serial Flash, 512 K x 16-bit SRAM and 128 Mbit NOR Flash
- 240x320 TFT color LCD connected to FSMC interface of STM32L152ZDT6
- Joystick with 4-direction control and selector
- Reset and Tamper or key button
- 4 color user LEDs
- 3 LEDs for MCU power range indicator
- MCU consumption measurement circuit
- 40x8 glass LCD segments connected to LCD driver of the STM32L152ZDT6
- Extension connector for daughterboard or wrapping board
- MCU voltage; 3.3 V or adjustable 1.65 V-3.6 V
- USB FS connector
- Touch slider
- Light dependent resistor (LDR)
- ADC/ DAC input signal connector
- MCU integrated op amp configured as Sallen-Key 2nd order low pass filter
- MCU integrated op amp configured as amplifier with adjustable gain
- Potentiometer
- JTAG and trace debug support
- Embedded ST-LINK/V2
Technical Documentation
Product Specifications
Description Version Size DB1558: STM32L152D-EVAL evaluation board 1.1 562 KB Application Notes
Description Version Size AN3429: STM32 proprietary code protection overview 1.1 60 KB Technical Notes & ArticlesUser Manuals
Description Version Size UM1510: STM32L152D-EVAL demonstration firmware 1.0 3 MB UM1521: STM32L152D-EVAL evaluation board 2.1 1 MB Hardware Resources
Description Version Size STM32L152D-EVAL gerber files 1.0 1 MB Bill of Materials
Description Version Size STM32L152D-EVAL BOM 1.1 6 KB Schematic Pack
Description Version Size STM32L152D-EVAL schematics 2.1 2 MB Publications and Collaterals
Flyers
Description Version Size STM32 for makers - Releasing your creativity 17.06 2 MB Brochures
Description Version Size STM32 32-bit MCU family - Leading supplier of ARM® Cortex®-M microcontrollers 17.10 2 MB Legal
License Agreement
Description Version Size Evaluation products license agreement 1.4 128 KB Open Reference Material License Agreement v5 42 KB TOOLS AND SOFTWARE
Development ToolsSOFTWARE DEVELOPMENT TOOLSEmbedded SoftwareMCUS EMBEDDED SOFTWARESAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office or our Distributors
QUALITY & RELIABILITY
Part Number RoHS Compliance Grade Material Declaration** STM32L152D-EVAL Ecopack1 (**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
조회수 2,168등록된 댓글이 없습니다.
