BASIC4MCU | ♧ STM32L4 | L476_ZG_EVAL | STM32L476G-EVAL
작성자 master 작성일2018-04-23 09:26 조회2,260회 댓글0건본문
STM32 MCU Eval Tools
ST's tools for evaluation of the STM32, range from highly affordable community enabled tools up to fully equipped boards, ready for evaluation of every single feature of the selected MCU. All ST evaluation boards include an ST-LINK/V2 in-circuit debugger/programmer.STM32 Nucleo boards follow a lean approach and are ideal for prototyping and community usage. An Arduino™connector and the ST Morpho connector make an extension with application related add-on hardware easy. All I/Os of the MCU are easily accessible, the boards come with a HAL library and work with IAR, Keil, CCC based IDEs as well as the mbed™ online IDE.
STM32 MCU Eval Boards
The STM32 eval boards have been designed as a complete demonstration and development platform for the ARM Cortex STM32 MCUs.
They carry external circuitry, such as transceivers, sensors, memory interfaces, displays and many more. The evaluation boards can be considered as a reference design for application development.
STM32L476G-EVAL
Evaluation board with STM32L476ZG MCUThe STM32L476G-EVAL evaluation board has been designed as a complete demonstration and development platform for STMicroelectronics ARM® Cortex®-M4 core-based STM32L476ZGT6 microcontroller with three I²C buses, three SPI interfaces, six USART ports, CAN port, SWPMI, two SAI ports, 12-bit ADC, 12-bit DAC, LCD driver, internal 128-Kbyte SRAM and 1-Mbyte Flash memory, Quad-SPI port, touch-sensing capability, USB OTG FS port, LCD controller, Flexible Memory Controller (FMC), JTAG debugging support.
The full range of hardware features on the board helps user to evaluate all the peripherals (USB OTG FS, USART, digital microphones, ADC and DAC, dot-matrix TFT LCD, LCD glass module, IrDA (supported up to version MB1144 C-01 of the board), LDR, SRAM, NOR Flash memory device, Quad-SPI Flash memory device, microSD™card, sigma-delta modulators, smartcard with SWP, CAN transceiver, I²C, EEPROM, RF-EEPROM) and develop applications. Extension headers allow easy connection of a daughterboard or wrapping board for a specific application.
An ST-LINK/V2-1 is integrated on the board, as embedded in-circuit debugger and programmer for the STM32 MCU and the USB virtual COM port bridge.
Key Features
- STM32L476ZGT6 microcontroller with 1-Mbyte Flash memory and 128-Kbyte RAM
- Four power supply options: power jack, ST-LINK/V2-1 USB connector, USB OTG FS connector, daughterboard
- Microcontroller supply voltage: 3.3 V or range from 1.71 V to 3.6 V
- Two MEMS digital microphones
- Two jack outputs for stereo audio headphone with independent content
- Slot for microSD™ card supporting SD, SDHC, SDXC
- 4-Gbyte microSD card bundled
- 16-Mbit (1M x 16 bit) SRAM device
- 128-Mbit (8M x 16 bit) NOR Flash memory device
- 256-Mbit Quad-SPI Flash memory device with Double Transfer Rate (DTR) support
- RF-EEPROM with I² C bus
- EEPROM supporting 1 MHz I² C-bus communication speed
- RS-232 port configurable for communication or STM32L476ZGT6 flashing
- IrDA transceiver (only supported up to MB1144 C-01 version of the board, no more supported from MB1144 C-02 version)
- USB OTG FS Micro-AB port
- CAN 2.0A/B-compliant port
- Joystick with four-way controller and selector
- Reset and wake-up / tamper buttons
- Touch-sensing button
- Light-dependent resistor (LDR)
- Potentiometer
- Coin battery cell for power backup
- LCD glass module daughterboard (MB979) with 40x8-segment LCD driven directly by STM32L476ZGT6
- 2.8-inch 320x240 dot-matrix color TFT LCD panel with resistive touchscreen
- Smartcard connector and SWP support
- NFC transceiver connector
- Connector for ADC input and DAC output
- Power-metering demonstration with dual-channel, sigma-delta modulator
- PT100 thermal sensor with dual-channel, sigma-delta modulator
- STM32L476ZGT6 current consumption measurement circuit
- Access to comparator and operational amplifier of STM32L476ZGT6
- Extension connector for motor-control module
- JTAG/SWD, ETM trace debug support, user interface through USB virtual COM port, embedded ST-LINK/V2-1 debug and flashing facility
- Extension connector for daughterboard
Technical Documentation
Product Specifications
Description Version Size DB2489: Evaluation board with STM32L476ZG MCU 3.0 328 KB Technical Notes & Articles
Description Version Size TN1235: Overview of the ST-LINK embedded in STM32 MCU Nucleo, Discovery Kits and Eval Boards 1.0 155 KB User Manuals
Description Version Size UM1855: Evaluation board with STM32L476ZGT6 MCU 5.0 4 MB Presentations & Training Material
Presentations
Description Version Size STM32L4 MCU series - Excellence in ultra-low-power with performance 4.0 1 MB Hardware Resources
Description Version Size STM32L476G-EVAL gerber files 1.0.0 1 MB Bill of Materials
Description Version Size STM32L476G-EVAL BOM 2.0.0 38 KB Schematic Pack
Description Version Size STM32L476G-EVAL Schematics 2.0.0 7 MB Publications and Collaterals
Flyers
Description Version Size STM32 for makers - Releasing your creativity 17.06 2 MB STM32L4 Series - Ultra-low-power and performance 17.07 770 KB Brochures
Description Version Size STM32 32-bit MCU family - Leading supplier of ARM® Cortex®-M microcontrollers 17.10 2 MB STM32L series - Ultra-low-power 32-bit MCUs 16.4 3 MB Legal
License Agreement
Description Version Size Evaluation products license agreement 1.4 128 KB Open Reference Material License Agreement v5 42 KB TOOLS AND SOFTWARE
Development ToolsSOFTWARE DEVELOPMENT TOOLSEmbedded SoftwareMCUS EMBEDDED SOFTWARESAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office or our Distributors
QUALITY & RELIABILITY
Part Number RoHS Compliance Grade Material Declaration** STM32L476G-EVAL Ecopack1 (**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
조회수 2,260등록된 댓글이 없습니다.
