BASIC4MCU | ♧ STM32L4 | L496_ZG_Nucleo | NUCLEO-L496ZG
작성자 master 작성일2018-04-23 09:27 조회1,922회 댓글0건본문
STM32 MCU Eval Tools
STM32 MCU Nucleo
All STM32 Nucleo users have free access to the mbed online resources (compiler, C/C++ SDK, and developer community) at www.mbed.org allowing to build a complete application in only a few minutes.
NUCLEO-L496ZG
STM32 Nucleo-144 development board with STM32L496ZG MCU, supports Arduino, ST Zio and morpho connectivityThe STM32 Nucleo-144 boards provide an affordable and flexible way for users to try out new concepts and build prototypes by choosing from the various combinations of performance and power consumption features, provided by the STM32 microcontroller. For the compatible boards, the SMPS significantly reduces power consumption in Run mode.
The ST Zio connector, which extends the Arduino™ Uno V3 connectivity, and the ST morpho headers provide an easy means of expanding the functionality of the Nucleo open development platform with a wide choice of specialized shields.
The STM32 Nucleo-144 board does not require any separate probe as it integrates the ST-LINK/V2-1 debugger/programmer.
The STM32 Nucleo-144 board comes with the STM32 comprehensive free software libraries and examples available with the STM32Cube MCU Package.
Key Features
- STM32 microcontroller in LQFP144 package
- External SMPS to generate Vcore logic supply (only available on '-P' suffixed boards)
- Ethernet compliant with IEEE-802.3-2002 (depending on STM32 support)
- USB OTG or full-speed device (depending on STM32 support)
- 3 user LEDs
- 2 user and reset push-buttons
- 32.768 kHz crystal oscillator
- Board connectors:
- USB with Micro-AB
- SWD
- Ethernet RJ45 (depending on STM32 support)
- ST Zio connector including Arduino™ Uno V3
- ST morpho
- Flexible power-supply options: ST-LINK USB VBUS or external sources
- On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability: mass storage, virtual COM port and debug port
- Comprehensive free software libraries and examples available with the STM32Cube package
- Support of a wide choice of Integrated Development Environments (IDEs) including IAR™ , Keil® , GCC-based IDEs, Arm®Mbed™
- Arm® Mbed Enabled™ compliant (only for some Nucleo part numbers)
Technical Documentation
Product Specifications
Description Version Size DB3171: STM32 Nucleo-144 boards 6.0 386 KB Technical Notes & Articles
Description Version Size TN1235: Overview of the ST-LINK embedded in STM32 MCU Nucleo, Discovery Kits and Eval Boards 1.0 155 KB User Manuals
Description Version Size UM1727: Getting started with STM32 Nucleo board software development tools 5.0 2 MB UM2179: STM32 Nucleo-144 boards 6.0 2 MB Hardware Resources
Description Version Size NUCLEO-L496ZG and NUCLEO-L496ZG-P gerber files 1.0 624 KB Bill of Materials
Description Version Size NUCLEO-L496ZG BOM 1.0 42 KB Schematic Pack
Description Version Size NUCLEO-L496ZG and NUCLEO-L496ZG-P Schematics 1.0 3 MB Publications and Collaterals
Flyers
Description Version Size STM32 Nucleo boards - Unified scalable offering 17.11 1 MB STM32 for makers - Releasing your creativity 17.06 2 MB STM32L4 Series - Ultra-low-power and performance 17.07 770 KB Brochures
Description Version Size STM32 32-bit MCU family - Leading supplier of ARM® Cortex®-M microcontrollers 17.10 2 MB STM32L series - Ultra-low-power 32-bit MCUs 16.4 3 MB Legal
License Agreement
Description Version Size Evaluation products license agreement 1.4 128 KB Open Reference Material License Agreement v5 42 KB TOOLS AND SOFTWARE
Development ToolsSOFTWARE DEVELOPMENT TOOLSEmbedded SoftwareMCUS EMBEDDED SOFTWAREEvaluation ToolsPRODUCT EVALUATION TOOLSSAMPLE & BUY
(*) Suggested Resale Price per unit (USD) for BUDGETARY USE ONLY. For quotes, prices in local currency, please contact your local ST Sales Office or our Distributors
QUALITY & RELIABILITY
Part Number RoHS Compliance Grade Material Declaration** NUCLEO-L496ZG Ecopack1 (**) The Material Declaration forms available on st.com may be generic documents based on the most commonly used package within a package family. For this reason, they may not be 100% accurate for a specific device. Please contact our sales support for information on specific devices.
조회수 1,922등록된 댓글이 없습니다.
