8051 > 8051 Instruction Set
TODAY577 TOTAL153,518
포럼 동영상강좌 회원가입
BASIC4MCU | 8051 | 8051 Instruction Set
작성자 키트 작성일2017-09-12 10:46 조회212회 댓글0건
~:  8051 Instruction Set  :~
Here one can find complete instruction set of 8051 micro-controller. Complete information regarding each instruction like operational explanation, addressing mode, no. of byte occupied, no. of cycles used etc is given. So just, go through it. It’s a ready reference.
All 8051 instructions are broadly classify in to four groups data moving, logical, arithmetic and branching.
Data moving / handling Instructions: -
Mnemonics
Operational description
Addressing mode
No. of bytes occupied
No. of cycles used
Mov a,#num
Copy the immediate data num in to acc
immediate
2
1
Mov Rx,a
Copy the data from acc to Rx
register
1
1
Mov a,Rx
Copy the data from Rx to acc
register
1
1
Mov Rx,#num
Copy the immediate data num in to Rx
immediate
2
1
Mov a,add
Copy the data from direct address add to acc
direct
2
1
Mov add,a
Copy the data from acc to direct address add
direct
2
1
Mov add,#num
Copy the immediate data num in to direct address
direct
3
2
Mov add1,add2
Copy the data from add2 to add1
direct
3
2
Mov Rx,add
Copy the data from direct address add to Rx
direct
2
2
Mov add,Rx
Copy the data from Rx to direct address add
direct
2
2
Mov @Rp,a
Copy the data in acc to address in Rp
Indirect
1
1
Mov a,@Rp
Copy the data that is at address in Rp to acc
Indirect
1
1
Mov add,@Rp
Copy the data that is at address in Rp to add
Indirect
2
2
Mov @Rp,add
Copy the data in add to address in Rp
Indirect
2
2
Mov @Rp,#num
Copy the immediate byte num to the address in Rp
Indirect
2
1
Movx a,@Rp
Copy the content of external add in Rp to acc
Indirect
1
2
Movx a,@DPTR
Copy the content of external add in DPTR to acc
Indirect
1
2
Movx @Rp,a
Copy the content of acc to the external add in Rp
Indirect
1
2
Movx @DPTR,a
Copy the content of acc to the external add in DPTR
Indirect
1
2
Movc a,@a+DPTR
The address is formed by adding acc and DPTR and its content is copied to acc
indirect
1
2
Movc a, @a+PC
The address is formed by adding acc and PC and its content is copied to acc
indirect
1
2
Push add
Increment SP and copy the data from source add to internal RAM address contained in SP
Direct
2
2
Pop add
copy the data from internal RAM address contained in SP to destination add and decrement SP
direct
2
2
Xch a, Rx
Exchange the data between acc and Rx
Register
1
1
Xch a, add
Exchange the data between acc and given add
Direct
2
1
Xch a,@Rp
Exchange the data between acc and address in Rp
Indirect
1
1
Xchd a, @Rp
Exchange only lower nibble of acc and address in Rp
indirect
1
1
Logical Instructions: -
Mnemonics
Addressing mode
No. of cycles used
Anl a, #num
AND each bit of acc with same bit of immediate num, stores result in acc
Immediate
2
1
Anl a, add
AND each bit of acc with same bit of content in add, stores result in acc
Direct
2
1
Anl a, Rx
AND each bit of acc with same bit of content of Rx, stores result in acc
Register
1
1
Anl a, @Rp
AND each bit of acc with same bit of content of add given by Rp, stores result in acc
Indirect
1
1
Anl add, a
AND each bit of acc with same bit of direct add num, stores result in add
Direct
2
1
Anl add, #num
AND each bit of direct add with same bit of immediate num, stores result in add
direct
3
2
orl a, #num
OR each bit of acc with same bit of immediate num, stores result in acc
Immediate
2
1
orl a, add
OR each bit of acc with same bit of content in add, stores result in acc
Direct
2
1
orl a, Rx
OR each bit of acc with same bit of content of Rx, stores result in acc
Register
1
1
orl a, @Rp
OR each bit of acc with same bit of content of add given by Rp, stores result in acc
Indirect
1
1
orl  add, a
OR each bit of acc with same bit of direct add num, stores result in add
Direct
2
1
orl add, #num
OR each bit of direct add with same bit of immediate num, stores result in add
direct
3
2
Xrl a, #num
XOR each bit of acc with same bit of immediate num, stores result in acc
Immediate
2
1
Xrl a, add
XOR each bit of acc with same bit of content in add, stores result in acc
Direct
2
1
Xrl a, Rx
XOR each bit of acc with same bit of content of Rx, stores result in acc
Register
1
1
Xrl  a, @Rp
XOR each bit of acc with same bit of content of add given by Rp, stores result in acc
Indirect
1
1
Xrl add, a
XOR each bit of acc with same bit of direct add num, stores result in add
Direct
2
1
Xrl add, #num
XOR each bit of direct add with same bit of immediate num, stores result in add
direct
3
2
Clr a
Clear each bit of acc
Direct
1
1
Cpl a
Complement each bit of acc
direct
1
1
Anl c, b
AND carry with given bit b, stores result in carry
2
2
Anl c, /b
AND carry with complement of given bit b, stores result in carry
2
2
Orl c, b
OR carry with given bit b, stores result in carry
2
2
Orl c, /b
OR carry with complement of given bit b, stores result in carry
2
2
Cpl c
Complement carry flag
1
1
Cpl b
Complement bit b
2
1
Clr c
Clear carry flag
1
1
Clr b
Clear given bit b
2
1
Mov c, b
Copy bit b to carry
2
1
Mov b, c
Copy carry to bit b
2
2
Setb c
Set carry flag
1
1
Setb b
Set bit b
2
1
Rl a
Rotate acc one bit left
1
1
Rr a
Rotate acc one bit right
1
1
Rlc a
Rotate acc one bit left with carry
1
1
Rrc a
Rotate acc one bit right with carry
1
1
Swap a
Exchange upper and lower nibble of acc
1
1
Arithmetic Instructions: -
Mnemonics
Addressing mode
No. of cycles used
Inc a
Add 1 to acc
Register
1
1
Inc Rr
Add 1 to register Rr
Register
1
1
Inc add
Add 1 to the content of add
Direct
2
1
Inc @rp
Add 1 to the content of the address in Rp
indirect
1
1
Inc DPTR
Add 1 to DPTR
Register
1
2
dec a
Subtract 1 from acc
Register
1
1
dec Rr
Subtract 1 from Rr
Register
1
1
dec add
Subtract 1 from content of add
Direct
2
1
dec @rp
Subtract 1 from the content of address
indirect
1
1
Add a, #num
Add the immediate num with acc and stores result in acc
immediate
2
1
Add a, Rx
Add the data in Rx with acc and stores result in acc
Register
1
1
Add a, add
Add the data in add with acc and stores result in acc
Direct
2
1
Add a, @Rp
Add the data at the address in Rp with acc and stores result in acc
Indirect
1
1
Addc a,#num
Add the immediate num with acc and carry, stores result in acc
immediate
2
1
Addc a, Rx
Add the data in Rx with acc and carry, stores result in acc
Register
1
1
Addc a, add
Add the data in add with acc and carry, stores result in acc
Direct
2
1
Addc a, @Rp
Add the data at the address in Rp with acc and carry, stores result in acc
Indirect
1
1
Subb a, #num
Subtract immediate num and carry from acc; stores the result in acc
immediate
2
1
Subb a, add
Subtract the content of add and carry from acc; stores the result in acc
Register
1
1
Subb a, Rx
Subtract the data in Rx and carry from acc; stores the result in acc
Direct
2
1
Subb a, @Rp
Subtract the data at the address in Rp and carry from acc; stores the result in acc
Indirect
1
1
Mul ab
Multiply acc and register B. store the lower byte of result in acc and higher byte in B
1
4
div ab
divide acc by register B. store quotient in acc and remainder in B
1
4
Da a
After addition of two packed BCD numbers, adjust the sum to decimal format
1
1
Branching Instructions: -
Mnemonic
No of bytes occupied
No. of cycles used
Jc label
Jump to label if carry is set to 1
2
2
Jnc label
Jump to label if carry is cleared to 0
2
2
Jb b,label
Jump to label if given bit is set to 1
3
2
Jnb b,label
Jump to label if given bit is cleared to 0
3
2
Jbc b,label
Jump to label if given bit is set. Clear the bit
3
2
Cjne a, add, label
Compare the content of accumulator with the content of given address and if not equal jump to label
3
2
Cjne a, #num, label
Compare the content of accumulator with immediate number and if not equal jump to label
3
2
Cjne Rx, #num, label
Compare the content of Rx with the immediate number and if not equal jump to label
3
2
Cjne @Rp, #num, label
Compare the content of location in Rp with immediate number and if not equal jump to label
3
2
Djnz Rx, label
Decrement the content of Rx and jump to the label if it is not zero
2
2
Djnz add, label
Decrement the content of address and jump to the label if it is not zero
3
2
Jz label
Jump to the label if content of accumulator is 0
2
2
Jnz label
Jump to the label if content of accumulator is not 0
2
2
Jmp @a+dptr
Jump to the address created by adding the contents on accumulator and dptr
1
2
Ajmp sadd
Take a jump to absolute short range address sadd
2
2
Ljmp ladd
Take a jump to absolute long range address sadd
3
2
Sjmp radd
Take a jump to relative address radd
2
2
nop
Short form of no operation means do nothing and go to next instruction
1
1
Acall sadd
Pushes the content of Acc on stack and load it will absolute short range address sadd
2
2
Lcall ladd
Pushes the content of Acc on stack and load it will absolute long range address sadd
3
2
Ret
returns from subroutine by restoring the Acc from stack using pop operation
1
2
reti
Returns from interrupt subroutine by restoring Acc from stack using pop operation
1
2
http://multyremotes.com/8051-instruction-set.htm
조회수 212
8051HOME > 8051/PIC > 8051 목록
                   MCU BASIC ⓒ 2017 모바일버전으로보기
