BASIC4MCU | 2017년 128강좌 | [OpenM128] Hardware design
작성자 키트 작성일2017-09-12 14:57 조회1,809회 댓글0건본문
OpenM128 Standard
AVR Development Board
AVR development board designed for ATMEL mega AVR, features the ATmega128 MCU, and integrates various standard interfaces, pretty easy for peripheral expansions.
OpenM128 Package A
OpenM128 Package B
AVR Development BoardContents
[hide]
- 1 Introduction
- 2 Overview
- 3 Hardware design
- 4 Basic Operation
- 5 Quick Start Demo
- 5.1 2.2inch LCD_Display
- 5.2 2.2inch LCD_Touch
- 5.3 8 Push Buttons
- 5.4 8 SEG LED Board
- 5.5 AD Keypad
- 5.6 I2C_AT24CXX
- 5.7 I2C_PCF8563
- 5.8 IO_FT245
- 5.9 Interupt_KEY4
- 5.10 JOYSTICK
- 5.11 KEY
- 5.12 LCD12864
- 5.13 LED
- 5.14 ONE WIRE_DS18B20
- 5.15 PS2
- 5.16 SPI_AT45DBXX
- 5.17 SPI_Debug
- 5.18 SPI_NRF24L01
- 5.19 T_C0_LED
- 5.20 USART
- 5.21 USART_Printf
- 6 References
- 7 Resources
- 8 Support
Introduction
More Overview
- This user manual contains schematic and demo of Waveshare OpenM128[1]development board. It helps you to quick start your AVR development.
Hardware design
- This chapter mainly about a basic idea of the hardware design of OpenM128. Go with you to witness how a ATmega128A-AU chip becomes OpenM128 board.
- First of all, we start from the common LED demo. This demo is an example of flashing alternately LED, controlled by the MCU. How do the MCU finish such a common demo? And what circuit work together?
- For the MCU system, actually its program controls the I/O pins to output high or low to turn on or turn off the LEDs. And the time span of the high or low output controls the time span of light up. Surely, the chip needs power supply to work; it needs clock circuit to control LED blink time; it needs Download/Configure circuits to program the compiled project; it needs reset circuits to reset and begin again. The pins of chip can be divided into I/O, SPI, I2C, USART interfaces and so on according to the features.
- Power supply circuit, a clock circuit, reset circuit and configuration circuit in above-mentioned are the necessary circuits of MCU development. So, many minimum system board just have these circuits and won't extend other feature interfaces. However, OpenM128 extends all chip interfaces of different kinds and gives you supporting function modules and drivers. Helps you to quick start all feature interfaces learning and to develop similar extends. A variety of circuits will be introduced in the following chapter.
Power Supply Circuit
- Power supply circuit is the basic circuit to drive OpenM128 development board. We can find that ATmega128A-AU works on 2.7V~5.5V in the datasheet[2]. And the board is designed for both 5V and 3.3V. The AMS1117-3.3 onboard is used for converting 5V to 3.3V, you can set the jumper to convert the MCU input voltage between 3.3V and 5V. In addition, the power supply circuit contains control switch, power LED, 3.3V/5V/GND pin out, that make control and inspection of power supply circuit more easily.
Pin Name Description 5V 5V supply input, it can be used as MCU or other peripherals VCC power supply. 3.3V 3.3V supply from AMS1117-3.3, it can be used as MCU or other peripherals VCC power supply. GND Ground VCC It is a pin corresponding to MCU VCC, you can set the jumper to convert the MCU input voltage between 3.3V and 5V. PWR_5V 5V input from a power supply. Clock Circuit
- There is a calibrated RC oscillator in the AVR MCU. So usually, extended clock circuit can be removed under less demanding circumstances on clock accuracy. For higher clock accuracy demand, OpenM128 is designed relative flexibly, it supplies optional oscillator crystal ports besides of onboard 7.3728M and 32.768K crystal. If the MCU RC oscillator is not suit your requirement, you can connect a right crystal and set the XTALn jumper to switch between XTAL1 and XTAL2.(Note: the corresponding fuse bit should be set by the program.)
Pin Name Description XTAL1 Inverting oscillator amplifier and on-chip clock operating circuit input XTAL2 Inverting oscillator amplifier output PG3 I/O pin, it can also be used as 32kHz crystal input PG4 I/O pin, it can also be used as 32kHz crystal input Reset Circuit
- Reset of AVR chip is low active, mean while that a 50 ns low signal input to reset pin will cause the chip reset. When you press the reset button, reset pin connects to negative power supply, and then, when you release the button, although the reset pin convert to high, actually the pressing time is more than 100 ms usually, it was enough for chip reset pulse transmission.
Pin Name Description nRST Chip reset, low active Download/configure circuit
- Download, also known as programming, is a chip programming and configuration process. AVR MCUs support ISP, JTAG, PDI download and so on. The first two are more commonly used. OpenM128 extends 2 kinds of download interface, they are a 10-pin-ISP, a 6-pin-ISP and a 10-pin-JTAG. You can connect standard AVR programmer or debugger[3] on it directly. You can download by JTAG or ISP, but only the JTAG interface supports both download and on-chip debug.
Pin Name Description MISO ISP, master in slave out (serial peripheral interface) MOSI ISP, master out slave in (serial peripheral interface) SCK ISP, Serial Clock,ISP operation is synchronous to SCK. TDI JTAG, JTAG Test Data In: Serial input data to be shifted in to the Instruction Register or Data Register(scan chains). TDO JTAG, JTAG Test Data Out: Serial output data from Instruction Register or Data Register. TMS JTAG, JTAG Test Mode Select: This pin is used for navigating through the TAP-controller state machine. TCK JTAG, JTAG Test Clock: JTAG operation is synchronous to TCK. Extension Circuit
- OpenM128 has various expansion circuit and the onboard LED, button ... make I/O operation easily; Some extensions, such as LCD, 16I/O, USART, PWM, I2C, SPI and so on, are not only the literal meaning for beginners. If you master these function interfaces, you will realize infinite charm from SCM. Many available powerful peripheral modules, GPS, WIFI, Graphic, Vedio, Intelligent recognition, can be interfaced to a variety of MCU. If all these modules were integrated into your development board, what surprising thing will you make!
Basic Operation
Power Up and Download
- Connect the programmer to your OpenM128 as shown in the following figure.
Quick Start Demo
- To use the following quick start demo, You should power up and download corresponding program to your board.
2.2inch LCD_Display
Demo Description
- 2.2inch Display Demo
Operation
Steps
- Take away the jumper 12864 JMP
- Connect 2.2inch 320x240 Touch LCD (A)[4] to LCD interface.
- Power up and download the program.
Phenomenon
- 2.2inch LCD will show different colored block.
2.2inch LCD_Touch
Demo Description
- 2.2inch Touch Demo
Operation
Steps
Phenomenon
- You will paint on the screen by touching and moving.
8 Push Buttons
Demo Description
- Press 8 Push Buttons to turn on or turn off the corresponding LEDs.
Operation
Steps
- Check the LED jumper position on the board, jumpers LED JMP on.
- Connect 8 Push Buttons[5] module to the GPIO interface.
Phenomenon
- Press key K0~K7, The corresponding LED will light up.
8 SEG LED Board
Demo Description
- Control 8 SEG LED Board via I/O port.
Operation
Steps
- Connect 8 SEG LED Board[6] to 16 I/Os port.
Phenomenon
- You will see four of the onBoard 8-SEG-LED will show numbers or English letters regularly.
AD Keypad
Demo Description
- Print A/D key value from the UART port. AD Keypad module has 16 keys but occupies only one AD I/O, helps you to save limited I/O resources.
Operation
Steps
- Connect AD Keypad[7] to ADC interface.
- Connect PL2303 USB UART Board (mini)[8] to USART0.
- Check your COM port and set baud rate to 9600.
Phenomenon
- COM port will receive A/D Key value.
I2C_AT24CXX
Demo Description
- Read and write AT24CXX EEPROM via I2C interface.
Operation
Steps
- Connect AT24CXX EEPROM Board[9] to I2C interface.
Phenomenon
- COM port will receive the data read from and written to EEPROM.
I2C_PCF8563
Demo Description
- Read and write the clock of PCF8563 RTC Board via I2C interface.
Operation
Steps
- Connect PCF8563 RTC Board[10] to I2C interface
Phenomenon
- COM port will receive the data from RTC Board.
IO_FT245
Demo Description
- Read and write FT245 FIFO data via I/Os.
Operation
Steps
- Take away the output-power-supply jumper from FT245 USB FIFO Board [11].
- Connect PC0~PC7 to LED0~LED7 with jumper wire.
- Connect the pin side of FT245 USB FIFO Board to 16 I/Os interface and the USB side to PC.
- Check your COM port and set baud rate to 19200.
Phenomenon
- COM port will receive ordered string 1~9. Some LED will be turned on corresponding to the COM port sending, For instance, if you send 0xCC, the LED will light up as binary "11001100".
Interupt_KEY4
Demo Description
- Use chip external interrupt, triggered from KEY4, to control the LED.
Operation
Steps
- Jumper LED_JMP ON.
Phenomenon
- Press KEY4, LEDs will light up increased, according to how many times the key pressed.
JOYSTICK
Demo Description
- LEDs' on or off will be switched according to JOYSTICK status.
Operation
Steps
- Set jumper LED JMP and JOYSTICK JMP ON.
Phenomenon
- Pull the Joystick to different position, the LEDs will be changed accordingly.
KEY
Demo Description
- LEDs' on or off will be switched according to the Key pressed.
Operation
Steps
- Jumper LED JMP and KEY JMP ON
Phenomenon
- Press KEY1~KEY4 separately, LEDs will be changed accordingly.
LCD12864
Demo Description
- Control screen LCD12864 by SPI and I/O interface.
Operation
Steps
- Jumper 12864 JMP ON. Warning: jumper VCC should be set to 3.3V, or too large voltage will cause LCD too bright and burned.
- Connect LCD12864[12] to LCD interface.
Phenomenon
- LCD12864 will show "waveshare".
LED
Demo Description
- Control LCDs by chip's I/O port.
Operation
Steps
- Jumper LED JMP ON.
Phenomenon
- 8 LEDs status will be toggled.
ONE WIRE_DS18B20
Demo Description
- Measure the temperature of DS18B20+ by One Wire port.
Operation
Steps
- Connect DS18B20+ to ONE WIRE port. Warning: Please make sure DS18B20+ is connected correctly to the ONE WIRE port, Arc side of DS18B20+ must match the sign of ONE WIRE port. Do NOT connect it reversely, or it may be burned.
- Connect PL2303 USB UART Board (mini).
Phenomenon
- COM port will receive corresponding temperature.
PS2
Demo Description
- Use PS/2 keyboard via PS/2 interface.
Operation
Steps
- Jumper PS/2 JMP ON.
- Connect PS/2 keyboard to PS/2 interface.
Phenomenon
- COM port will receive corresponding information input from the keyboard.
SPI_AT45DBXX
Demo Description
- Read and write AT45DBXX DataFlash Board, an external expansion memory module board, via SPI interface.
Operation
Steps
- Connect AT45DBXX DataFlash Board[13] to SPI interface
Phenomenon
- COM port will receive the data read from and written to DataFlash.
SPI_Debug
SPI_NRF24L01
Demo Description
- This is a demo of NRF24L01 wireless communication.
Operation
Steps
- Prepare two OpenM128 and two NRF24L01 boards, for sending, TX, and receiving, RX, data. The following is an example of 2 OpenM128 boards.
- Connect two NRF24L01 RF Boards[14] to the SPI interface of OpenM128 boards separately.
- Connect the RX board to a PC via PL2303 USB UART Board.
Phenomenon
- COM port will receive the data from TX board to RX board.
T_C0_LED
Demo Description
- Control LEDs' status by I/Os and Timer 0(T/C0).
Operation
Steps
Phenomenon
USART
Demo Description
- USART0:USART0 self-send-self-receive test.
- USART1:USART1 to send 'U' automatically.
Operation
Steps
- Connect PL2303 USB UART Board (mini) to UART0 (or UART1)
Phenomenon
- USART0:The information sent by PC's COM port will be received from the same port.
- USART1:USART1 will send 'U' automatically.
USART_Printf
Demo Description
- COM port will receive the data from USART0 interface.
Operation
Steps
- Connect PL2303 USB UART Board (mini) to UART0.
Phenomenon
- The program will send data via USART0 automatically, and then, COM port will receive the data from USART0 interface.
References
- Jump up↑ OpenM128 development board
- Jump up↑ ATmega128A datasheet
- Jump up↑ AVR programmer or debugger
- ↑ Jump up to:4.0 4.1 2.2inch 320x240 Touch LCD (A): Please click in Graphic-Lcd for more details about touch LCD.
- Jump up↑ 8 Push Buttons
- Jump up↑ 8 SEG LED Board
- Jump up↑ AD Keypad
- Jump up↑ PL2303 USB UART Board (mini)
- Jump up↑ AT24CXX EEPROM Board
- Jump up↑ PCF8563 RTC Board
- Jump up↑ FT245 USB FIFO Board (mini)
- Jump up↑ LCD12864-ST (3.3V Blue Backlight)
- Jump up↑ AT45DBXX DataFlash Board
- Jump up↑ NRF24L01 RF Board (B)
Resources
File:OpenM128-Schematic.pdf
OpenM128-Schematic.pdf (0 × 0 pixels, file size: 533 KB, MIME type: application/pdf)MsUpload
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time Dimensions User Comment current 08:18, 27 March 2015 0 × 0 (533 KB) Wiki Editorial Team (Talk | contribs) MsUpload File:OpenM128-Demo.7z
OpenM128-Demo.7z (file size: 467 KB, MIME type: application/acad)Warning: This file type may contain malicious code. By executing it, your system may be compromised.MsUpload
File history
Date/Time Dimensions User Comment current 07:44, 2 April 2015 (467 KB) Wiki Editorial Team (Talk | contribs) MsUpload File:ATmega128A.pdf
ATmega128A.pdf (0 × 0 pixels, file size: 7.36 MB, MIME type: application/pdf)MsUpload
File history
Date/Time Dimensions User Comment current 01:38, 10 April 2015 0 × 0 (7.36 MB) Wiki Editorial Team (Talk | contribs) MsUpload AVR Software
File:CP210x USB TO UART.zip
CP210x_USB_TO_UART.zip (file size: 188 KB, MIME type: application/zip)Warning: This file type may contain malicious code. By executing it, your system may be compromised.MsUpload
File history
Date/Time Dimensions User Comment current 02:46, 2 March 2015 (188 KB) Wiki Editorial Team (Talk | contribs) MsUpload File:FT232-Driver.7z
FT232-Driver.7z (file size: 644 KB, MIME type: application/acad)Warning: This file type may contain malicious code. By executing it, your system may be compromised.MsUpload
File history
Date/Time Dimensions User Comment current 08:08, 3 April 2015 (644 KB) Wiki Editorial Team (Talk | contribs) MsUpload File:FTDI-Driver.7z
FTDI-Driver.7z (file size: 2.49 MB, MIME type: application/acad)Warning: This file type may contain malicious code. By executing it, your system may be compromised.MsUpload
File history
Date/Time Dimensions User Comment current 01:26, 10 April 2015 (2.49 MB) Wiki Editorial Team (Talk | contribs) MsUpload File:Ultra-Serial-Port-Monitor.7z
Ultra-Serial-Port-Monitor.7z (file size: 759 KB, MIME type: application/acad)Warning: This file type may contain malicious code. By executing it, your system may be compromised.MsUpload
File history
Date/Time Dimensions User Comment current 03:39, 3 April 2015 (759 KB) Wiki Editorial Team (Talk | contribs) MsUpload
조회수 1,809등록된 댓글이 없습니다.
